CUCM 5.1 - Permissions
Mar 9th, 2009
  • Silver, 250 points or more
I'm having an issue on a 5.1 cluster under end user config. The "View Details" link under "Permission Information" (for Groups and Roles) doesn't do anything.
I've tried firefox, IE, and safari and nothing happens when I click on the "View Details" links.
Any ideas?
thanks,
Will
markcarat Mon, 03/09/2009 - 10:50
Hi Will,
Try to select the Groups/Roles then click on the "View Details"
Hope this helps
Mark
will.alvord Mon, 03/09/2009 - 11:11
Still nothing. The only workaround that I've found is to go into the groups and add the users that way.
It's kind of a pain, but there aren't many of these types of changes needed so it's bearable. I was just curious if anyone had found a better workaround or if anyone else is actually seeing this bug.
thanks,
Will
