Problems with migrating from Pix til ASA using pixtoasa.exe
Mar 9th, 2009
I have just started the process with migrating from PIX to ASA-platform. I have used to pixtoasa.exe-tool several times to convert my existing PIX-config to ASA 5520-config, this has been working ok. But after the last time I reset the ASA to factory-default it will not accept the intermediate config from pixtoasa.exe anymore. I am doing as follows:
1: Running the tool with the PIX-config as input, no erros occurs during this process.
2: Copy the output to the ASA via TFTP
3: Copy the file into startup-config
4: reload
During boot the ASA shows a lot of errors, it seems the it does not accept the syntax of the PIX-commands, i.e. VPNGROUP-commands, that should be converted during boot. Any tips on thiswould be great. Do I have have set the ASA into a special mode to force it to convert the config? Thanks!
smalkeric Sun, 03/15/2009 - 14:03
  • Silver, 250 points or more
I recommend that you use the tool-assisted conversion for converting PIX configurations to ASA configurations. This method uses two tools, the Outbound Conduit Conversion Tool and the Cisco PIX-to-ASA migration tool, to convert Cisco PIX Software version 6.3(x), 7.x, or 8.0 configurations to configurations that are usable on a Cisco ASA 5500 Series Adaptive Security Appliance.
http://www.cisco.com/en/US/docs/security/asa/migration/guide/pix2asa.html#wp279448
