IPsec tunnel for remote access vpn users on loopback interface
Mar 9th, 2009
I want to terminate ipsec tunnel for the remote access vpn on the loopback interface of the ASA. Is it possible and how do i achieve it.
Pl help
auraza Mon, 03/09/2009 - 10:52
There is no loopback interface on the ASA at the moment. Is there a reason you want to use a loopback interface?
9898nishit Tue, 03/10/2009 - 01:29
Thanks for your reply. Outside of the ASA will connect to our internet gateway router and to terminate vpn tunnel on ASA i have to assign one public ip on outside of the ASA and one public ip on inside of our internet gateway router.
I am planing to use private ips between outside of my ASA and inside of our internet router. In this case i will assign public ip to loopback of my ASA and terminate tunnel on this loopback.
auraza Tue, 03/10/2009 - 02:10
The ASA doesn't allow for loopback interfaces at the moment, so that won't be possible.
9898nishit Tue, 03/10/2009 - 02:57
Thanks Auraza,
Now i will work on some other solution.
