6509 w/ SUP2: getting "unsupported feature" error with redundancy commands
miked
I have a 6509 w/ dual/redundant SUP2 cards.
When running these commands on the main console:
redundancy
main-cpu
auto-sync startup-config
auto-sync running-config
auto-sync config-register
auto-sync bootvar
auto-sync standard
All of the “auto-sync” commands fail stating: “This command is an unreleased and unsupported feature”
When doing a “show ?” under main-cpu all it shows is “default” “exit” and “no”, so I'm not seeing any options for these commands. Are there any new commands that replace the “auto-sync” commands? I've been scouring Cisco and Google sites all morning with no luck.
Thanks, Mike
adamclarkuk_2
Level 4
Level 4
auto-sync is definitely the command you need. What is the IOS you are running ?
I'm running 12.2.18SXF15a
Funny this is, the commands show up in the running config (and startup after doing a wr mem). And, when I make changes and save them it shows me a meesage that it's sync'ed to the standby SUP2.
It is the latest IOS, but I haven't found anything about this as far as open issues with it. And the version does support RPR+ too.
