03-09-2009 12:40 PM - edited 03-15-2019 04:43 PM
We are integrating a PBX to CM through a gateway using MGCP signaling. The gateway has a 4-FXS/DID card. I noticed when I was configuring the gateway in CallManager it had a mandatory field called "attendant DN". I thought digits could be passed incoming/outgoing of the FXS ports so what would the purpose of the "attendant DN" be?
Is it just one direction digits are passed? For example, from FXO to FXS or the other direction?
I have read different things about whether FXO/FXS supported sending digits through DTMF. I am confused if I really need the attendant DN in CM, however it is a mandatory field.
03-09-2009 01:18 PM
The 'Attendant DN' is used if you need to route the call coming in on the line to a specified DN.
03-09-2009 01:34 PM
I understand that but will the FXS card on the gateway accept digits from the PBX? The PBX would be acting as the FXO and the voice gateway has an FXS.
03-09-2009 02:05 PM
