Any CDR Experts?
Mar 9th, 2009
Can anyone provide me a clarification given the following Cisco definitions:
finalCalledPartyNumber
For forwarded calls, this number designates the last party to receive the call.
lastRedirectDn
For forwarded calls, this field designates the last party to redirect the call.
Wouldn't these 2 always be the same number? Example of when they're not? Can't seem to visualize it, gratefual for any help! Thanks, Kelly
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 03/09/2009 - 14:20
they sound similar but they're not
finalCalledPartyNumber is the actual last DN CUCM dialed
ie 5560 CFA to 91978XXXXXXX
then it would be 91978XXXXXXX
if you apply called party masks using a translation pattern then what you have configured shows up if you hit the translation pattern, let's say a PLAR is an example, you don't dial but you'll get the value for called party mask
lastRedirectDn, from previous example shows 5560 as it was the last party that had a redirect instruction for the call
java
if this helps, please rate
