CME Setup
Kenneth Mohammed Mon, 03/09/2009 - 14:40
  • Silver, 250 points or more
The number of phones and extensions you can support on your CME is based on router platform and IOS version.
Check this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
and here is the CME version/IOS compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Hope that helped, if so please rate.
snickered Mon, 03/09/2009 - 15:00
You don't have to install a license file. And, yes, the router can be the tftp-server for the phones.
Jaime Valencia Mon, 03/09/2009 - 15:22
  • Cisco Employee,
  • Hall of Fame,
    2011
SCCP: Setting Up Cisco Unified CME
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1023245
Router is the TFTP, the guides have all the info on this.
the licensing is honour based, so even if you don't need an actual file you do need to buy it for legal terms. similar to IPC before, the license was just a piece of paper but you had to buy if to be licensed to use it even if it's not really necessary to install or use IPC
java
if this helps, please rate
