WAAS not working
Mar 9th, 2009
Can you please advise us on what IOS code we should be using on our 2811 router to support WAAS and The HWIC -1FE module.
We were using the following code on our router and WAAS was working
c2800nm-advipservicesk9-mz.124-3c.bin
We needed to install a HWIC -1FE module in our 2811 router so we found the following code supported the module but now WAAS is not working
c2800nm-advipservicesk9-mz.124-11.XJ4.bin
Can you please advise us on the best possible code to use that will support the above.
dstolt Mon, 03/09/2009 - 18:53
Sean,
The T train code I found is 12.4(24)T, so you can start looking there as it's way more mainstream then the XJ code trains, however, it's brand new. You should definitely test it to ensure it meets your need before putting it into production.
Hope that helps,
Dan
