VPN Client not getting network connection
Mar 9th, 2009
I have configured a VPN client connection in a PIX 506. The VPN client user gets a solid connection to the pix & an IP address assignment from the pool. But he is unable to connect to any address on the local network.
John G.
JORGE RODRIGUEZ Mon, 03/09/2009 - 17:15
  • Green, 3000 points or more
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#Solution1
John,
Most posible causes could be you need to enable NAT traversal on your firewall .
pix(config)#isakmp nat-traversal 20
If alreayd configured and still RA have no access check your nat exempt access-list to make sure you are allowing RA VPN pool network access to your LAN resources..
