VLAN Access-list (access-group Traffic in/out)
Mar 9th, 2009
  • Silver, 250 points or more
I am having a problem that does not make sense to me. I have a switch configured with a single (VLAN4) to which I tried to apply an ACL that will impact traffic coming from worstations in VLAN4.
Once i apply the acl below, I can longer telnet from a host that is sourcing from a remote office nor from the workstations in vlan4.
ip access-list extended vlan4_traffic
permit udp any any eq bootps
permit udp any any eq bootpc
permit ip host 10.64.4.19 10.80.0.0.0 0.0.255.255
permit tcp any 10.80.2.0 0.0.0.255 eq 11141
permit tcp any 10.80.2.0 0.0.0.255 eq 11110
permit tcp any 10.80.2.0 0.0.0.255 eq 11001
permit tcp any 10.80.2.0 0.0.0.255 eq 6010
permit tcp any 10.80.2.0 0.0.0.255 eq 11167
permit tcp any 10.80.2.0 0.0.0.255 eq 17777
permit tcp any 10.80.2.0 0.0.0.255 eq 13183
permit tcp any 10.80.2.0 0.0.0.255 eq 1433
permit tcp any 10.80.2.0 0.0.0.255 eq 11025
permit tcp any any eq 3389
permit ip any host 10.80.2.18
permit ip any host 10.80.2.22
permit ip any 10.80.2.0 0.0.0.255
permit ip any 10.80.3.0 0.0.0.255
permit ip any 10.80.4.0 0.0.0.255
permit icmp any any
permit tcp any any established
deny ip any 10.80.0.0 0.0.255.255
deny ip any 10.64.0.0 0.0.255.255
permit ip any any
int vlan 4
ip address 10.64.4.254 255.255.255.0
ip access-group vlan4_traffic in
This acl I thought should affect incoming traffic from 10.64.4.0/24 subnet only.
adamclarkuk_2 Mon, 03/09/2009 - 17:07
Can you just give us an example of traffic flow, ie src IP,dst IP, dst port(guessing 23), also, on your deny's add a log entry, then do sh show log to see if they are blocking the traffic.
deny ip any 10.80.0.0 0.0.255.255 log
deny ip any 10.64.0.0 0.0.255.255 log
Tshi M Mon, 03/09/2009 - 17:21
Hi Adam,
Yes, I already did a log on the ACL that adds to my confusion. In any case, I am trying to telnet from 10.64.148.108 to 10.64.4.54 to no avail once the acl is applied to vlan4.
Traffic from vlan4 should be allowed for what it is on the acl only.
denied tcp 10.64.148.108(2020) -> 10.64.4.254(23), 1 packet
adamclarkuk_2 Mon, 03/09/2009 - 17:27
So, this line is denying the flow :-
Add this before the deny's
permit tcp any 10.64.4.0 0.0.0.255 eq 23 10.64.0.0 0.0.255.255
Not sure why it's ignoring your line
Tshi M Mon, 03/09/2009 - 17:36
Hi Adam,
I thought of that but the problem is that we have remote locations all starting with that 10.64.
The ACL shouldn't have any affect with outside incoming traffic as it "SHOULD" only apply to incoming VLAN4 traffic.
Tshi M Mon, 03/09/2009 - 17:47
Here it is my friend.
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48TS 12.2(46)SE C3560-IPBASEK9-M
adamclarkuk_2 Mon, 03/09/2009 - 17:52
Odd, can you apply a permit ip any any log and apply it inbound, then view the logs, it's almost as if it's doing the in/out the wrong way around :-s
Tshi M Mon, 03/09/2009 - 17:57
You read my mind for it is what i just did. I also changed a line to use log on it to see. The outcome is more confusing. The permit ip any any log, does show some traffic but the line
permit tcp any host 10.200.32.170 eq 11025 log, does not show anything. I applied that acl as "out" rather "in"
adamclarkuk_2 Mon, 03/09/2009 - 18:03
Try this one :-
permit ip host 10.64.4.54 host 10.64.148.108 log
permit ip any any
Then apply the ACL inbound, telnet from 10.64.4.54 to 10.64.148.108 and see if you get a hit, then flip it.
Tshi M Mon, 03/09/2009 - 18:27
only when i used permit ip host 10.64.148.108 host 10.64.4.54 and assign "in" than it works. So, it seems as though the acl should be applied using "out" on this vlan. It doesn't make sense to me.
adamclarkuk_2 Mon, 03/09/2009 - 18:32
Nor, me why would the 3560 be different to all the other Cat's when it comes to VLAN ACL's. I wonder if it's a code issue, I have some 3560's I can test with at the office, I will have a go tomoz.
Tshi M Tue, 03/10/2009 - 13:00
When applying the ACL using the "out" option, it does not seem to have any effects because I don't see any hit counts and some traffic that should be denied seems to pass through.
Richard Burts Tue, 03/10/2009 - 15:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Etienne
When you change the way that you apply the access list from in to out, you have a very significant change about what is the source address and what is the destination address. Did you re-write the access list when you changed its direction?
Perhaps it would help us if we could see a more complete config. Could you post the config (especially including not only the interface and access list, but also any routing information and the config of the vty lines)?
Rick
Richard Burts Tue, 03/10/2009 - 15:33
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Etienne
In re-reading this thread another question occurs to me. Where is the traffic from 10.64.148.108 coming from? How does that traffic get to your switch? Which interface does it arrive on? If we could see the complete config then perhaps we could figure this out.
Rick
Tshi M Tue, 03/10/2009 - 17:19
Hi Rick,
The traffic coming via a router that is connected to port 47 (see below) on the switch. I don't manage that router. There is a static route on the switch for that traffic (see below).
interface GigabitEthernet0/47
description Unmanaged Router
switchport access vlan 45
switchport mode access
load-interval 30
speed 100
duplex full
ip route 0.0.0.0 0.0.0.0 10.64.4.1
ip route 10.64.148.0 255.255.255.0 10.64.4.10
ip route 10.80.0.0 255.255.0.0 10.64.4.10
Tshi M Tue, 03/10/2009 - 18:47
I had a typo but this and the acl are pretty much the relevant lines of the config.
load-interval 30
speed 100
duplex full
line vty 0 4
exec-timeout 45 0
login local
Richard Burts Tue, 03/10/2009 - 19:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Etienne
The additional information is quite helpful. It confirms that your attempt to telnet is coming in on VLAN 4.
If you look carefully at the access list there are no statements that specify 10.64.148.0 as a source address. The first statement in the access list which would apply to this traffic from 10.64.148.0 to 10.64.4.254 is this line:
which clearly denies your attempt to telnet. If you want telnet to work you need to insert a line in the access list which permits the traffic and which comes before this line:
Rick
Tshi M Tue, 03/10/2009 - 19:38
Hi Rick,
My goal is to restrict workstations within VLAN4 going out to some specific servers and ports and not to restrict access in from outside the switch.
Thanks much,
