Problem with Internation Call
Mar 9th, 2009
Hi Guys,
My Customer have a one CCM version 4.1 in USA. And we are have the following problem: The Internation Call work when to do the call is did the USA to France, Mexico, Italy, but don't work to Brasil. The Carrier is the same and the CCM using the same route pattern to this call. In Gateway is configured only a one dial peer to internation call. I verify that call to Brasil have a one digit more. Can this the cause of problem? Are there different configuration in CCM or Gateway to do?
Jaime Valencia Tue, 03/10/2009 - 07:49
if the extra digit makes it un-routable of course ir can cause problems
check the whole routing and the GW config to see where you're adding that digit
if this helps, please rate
