4510 R switch - stuck in ROMMON
Mar 10th, 2009
Switch stuck in ROMMON Prompt and giving following error.
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
Switch running with IOS cat4000-i5k91s-mz.122-25.EWA10
Leo Laohoo Tue, 03/10/2009 - 14:03
Try "dir flash:" and look for the IOS file. When you find it, try the following commands: boot flash:filename
asfar.zaidi Wed, 03/11/2009 - 03:55
I have tried all these options not working.
Guys!!!!
I tried putting Compact flash with a valid IOS in it and when I issue command dir slot0: , it is giving error
device does not contain a valid magic number
dir: cannot open device "slot0:"
Any idea about this , Appreciate quick response.
adamclarkuk_2 Wed, 03/11/2009 - 04:27
It sounds like the the file is corrupt.
Try another flash card, or booting from TFTP. You can also copy another image via xmodem.
