on multilink interface ip load-sharing per-packet in not available
Mar 10th, 2009
When tring to enable this command i am not geting the per-packet option
7609-2(config)# int mul 11
7609-2(config-if)#ip load-sharing
7609-2(config-if)#ip load-sharing ?
per-destination Deterministic distribution
Is there any hidden command
dCEF is enabled
Image is 12.2(33)SRA5
GK
Brandon Buffin Tue, 03/10/2009 - 06:23
  • Purple, 4500 points or more
GK,
On the 7600 series, you can only using per-packet load sharing for software switching using the MSFC. You cannot perform per-packet load sharing in hardware.
Hope this helps.
Brandon
