DECT/Wifi phones
Mar 10th, 2009
Hi, I have to replace the current DECT system of one of our sites. We already have a callmanager 6.1 available. We also have some Cisco AP 1131AG's at this site. I have two questions about this:
1.Do I need a WLC if I want to roam between AP's with a 7921G phone? Or is this also possible with standalone AP's?
2.What are cheaper alternatives then the 7921G? May also be a DECT system. I need around 5 base-stations and 20 phones. But I must be able to roam between the base-stations.
Thanks in advance!
Overall Rating: 4 (1 ratings)
Georgios Nikitas Wed, 03/11/2009 - 00:31
A Wireless Lan Controller is not necessary in order to roam between AP's. I have several standalone installations that roam just fine. But I would recommend to have a cisco access switch to connect your access points to.
There are no cheaper alternatives from Cisco.
You may use third party SIP wireless phones that connect to the CallManager but I am not sure how well the roaming would work. It's up to you to take the risk or to perform some tests.
jmaat Wed, 03/11/2009 - 01:17
Thanks a lot for your answer! We do have a Cisco network on this location, so that shouldn't be the problem...
I think I am going to buy some 3rd party SIP phones to try... Please let me know if somebody knows a cheap DECT vendor or a good 3rd party SIP phone which can roam between AP's.
Georgios Nikitas Wed, 03/11/2009 - 04:12
I am also interested in learning about experiences with 3rd party wireless SIP phones and how well they roam and interoperate with Cisco Callmanager.
Jmaat, if you try I would appreciate it if you could inform me too :)
