on multilink interface ip load sharing per-packet is not available on 7609
Mar 10th, 2009
7609(config)# int mul 11
7609(config-if)#ip load-sharing
7609(config-if)#ip load-sharing ?
per-destination Deterministic distribution
7609-2(config-if)#ip load-sharing
dCEF is enabled,
is there any hidden command or any software bug, i am using 12.2(33)SRA5 or suggest IOS which supports this
the following command is also not available
Globalconfig#hw-module slot <no> per-packet
it is very urgent kindly help me out
Overall Rating: 3 (1 ratings)
pkurdziel Tue, 03/10/2009 - 06:20
ip load-sharing is used under the physical interface.
With a multi link you are already load sharing with the circuits that are bundled.
sgopikrishnan Tue, 03/10/2009 - 06:36
In 7206 the same is working fine on mulilink interface.
In 7609 on the physical interface also shows the same (per-packet option is not seen)
Giuseppe Larosa Tue, 03/10/2009 - 07:37
  • Hall of Fame,
    Founding Member
Hello Gopikrishnan,
a PPP multilink bundle already perform per PPP frame load balancing over member links on its own, so the practical effect of the command even if supported would be none.
Hope to help
Giuseppe
sgopikrishnan Tue, 03/10/2009 - 10:12
hi Giuseppe,
you mean that in an bundled PPP multilink link it is per packet(by default). But in show commands it does not say.
>>when CEF or dCEF is enabled it is by default per-destination.
You can see the output on the another router 7206 which has 12.2(28).SB8
Multilink interface
>>7206(config)#int mul 11
7206(config-if)#ip load
7206(config-if)#ip load-sharing ?
per-packet Random distribution
Giuseppe Larosa Tue, 03/10/2009 - 10:35
  • Hall of Fame,
    Founding Member
Hello Gopikrishnan,
actually being each PPP frame sent out one of the member links in a round robin fashion what you get is a fair per packet load balancing.
This something that happens at the MLPPP level code:
for CEF only the L3 interface multilink exists (and this is only one interface).
Then MLPPP feature manages the member links.
So you should already have per-packet load sharing but it is not done by CEF switching process.
you can use
sh ppp multilink
sh int type x/y for each member link to verify that all links are used in a fair way.
Look at the counters and you will see fair use of member links
Hope to help
Giuseppe
sgopikrishnan Tue, 03/10/2009 - 22:35
Hi Giuseppe,
if you have any docs related to this, that would be nice.
Gopikrishnan
sgopikrishnan Wed, 03/11/2009 - 05:04
I will check it out and surely revert back for any questions. thank u for ur help. probably by nextweek
Gopikrishnan.s
