Remote Access VPN on 1861
Answered Question
Mar 10th, 2009
Id like to configure Remote Access VPN on an 1861 for teleworkers who will use Cisco VPN client to access head office where the 1861 is located.
I was hoping to use SDM or CCA to point and click my way through the setup as I'm not a security guru, but the 1861 isnt supported it either yet. Does anyone have a config guide to configure these on IOS. I know how to configure them on a PIX but the config doesn't "translate"
Correct Answer by Ivan Martinon about 7 years 7 months ago
Hi, this might be useful for you:
NOTE: regardless of being a "different" platform, it applies to all ios routers.
Overall Rating: 5 (1 ratings)
