SNMP monitoring on cat6500
Mar 10th, 2009
Greetings to All !!
I need help on monitoring the following using SNMP, can you please guide me for the following.
1. Switch, Switch Ports and Modules availability monitoring
2. Port-wise Traffic Monitoring
3. CPU Utilization
4. Memory Utilization
5. Voltages, Temperatures
6. Collisions
7. Buffer Statistics (Hits, misses and failures)
Thanks in advance!
sivaprakasam81 Tue, 03/10/2009 - 11:19
Hi Experts,
Please help me out, to monitor the above hardware status monitoring using SNMP.
What parameter, should be used to get the status of the above hardware.,
Example ,
show module : Status : OK -- notify any changes
show environment : temp : Ok -- notify any changes.
How can i get this informtaion using SNMP? Do i need to use SNMP or MIB?
Thanks in advance!
