03-10-2009 06:33 AM - edited 03-11-2019 08:02 AM
I am planning to upgrade the system compact flash in an ASA5520. Once I install the new flash, I am left without an OS to boot from. Is there an alternative to tftp from rommon to get the image onto the flash ?
many thanks
Solved! Go to Solution.
03-10-2009 09:44 PM
ASA5520 has a slot for external flash card. You can copy the image to there and boot the box from external flash. After you replace internal flash, you can copy image back to it and change "boot system" statement to point back to internal flash.
03-10-2009 09:44 PM
03-12-2009 10:52 AM
thank you, that's excellent news. I wasn't sure if I could boot from the front Flash card.
10-03-2010 11:59 PM
What if I have VPN plus licence,
will I lose it? What should I do to upgrade the internal CF and not lose my
VPN+ ?
Thank you!
