QoS question - Is this possible
Mar 10th, 2009
  • Purple, 4500 points or more
All,
I don't think this is possible without extra equipment/software, but I wanted to ask.
Is there a way that I can create a time-based ACL and apply that policy-map to the ACL (or vice-versa)?
What I want to do is restrict flash applications between 5 - 7:30PM. I know that I can restrict URLs through a class-map, so I thought I would be able to restrict *.flv and *.swf between that time. Is there a way to do it?
I have either an 871W or an ASA that I can do this on. (The ASA is behind the 871W.)
John
Overall Rating: 5 (2 ratings)
mikegrous Tue, 03/10/2009 - 08:36
My example would be for a router. Not sure if the ASA has the features to do this but if it does this should work with some modification to fit for the ASA.
You would write your ACL that matches ip access-list 100 permit ip any any time-range TIME (specify this range with the time-range command in global config.)
class-map match-all CLASSMAP
this class map would then match the ACL
and it would then match your *.flv using NBAR
policy-map 1
class 1
shape? or police or drop or whatever..
nbar doc )http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/clsfy_traffic_nbar_ps6017_TSD_Products_Configuration_Guide_Chapter.html
John Blakley Tue, 03/10/2009 - 09:46
Thanks for this Mike! I'm going to try it tonight.
John
adamclarkuk_2 Tue, 03/10/2009 - 08:48
  • Silver, 250 points or more
The ASA does support time-ranges :
time-range working_hours
periodic weekdays 9:00 to 17:00
access-list limit extended permit ip host x.x.x.x any time-range working_hours
You can also use regexp within a policy-map to search for what you need :-
regex blockex1 ".flv"
regex blockex2 ".swf"
class-map type inspect http match-all block-flv
match request header host regex blockex1
match access-list
class-map type inspect http match-all block-swf
match access-list
policy-map type inspect http block-url-policy
parameters
class block-flv
drop-connection log
class block-swf
drop-connection log
policy-map global_policy
class inspection_default
service-policy global_policy global
John Blakley Wed, 03/11/2009 - 04:31
Okay, so this didn't work the way that I wanted. The embedded videos still play. In the following example, I tried to block javascript because I noticed that java was loading for a certain game site, but that didn't work either:
Class-map: NO_FLASH (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 151
Match: protocol http url "*.js"
drop
class-map match-all NO_FLASH
match access-group 151
match protocol http url "*.js"
access-list 151
10 permit ip host 10.20.1.100 any
policy-map OUTBOUND
class ROKU-OUTBOUND
priority percent 25
class NO_FLASH
drop
class class-default
fair-queue 256
int fa4
service-policy output OUTBOUND
I also tried mime type "video/x-flv" and I could still play videos. I also tried to match on .swf, .flv, and .js (exampled above). NBAR doesn't have a type that matches flash, so my thought is because http is allowed out, I may not be able to block it using "normal" methods. The urls are randomnized, so I'd have to block the whole site. The problem with that is I don't know how many sites I need to block, and I wanted to just block the filetypes.
Any other ideas?
Thanks!
John
adamclarkuk_2 Wed, 03/11/2009 - 04:36
Did you enable nbar on the correct interfaces with the interface level command
ip nbar protocol-discovery
John Blakley Wed, 03/11/2009 - 05:12
Yes, and I forgot to paste that information in. Here's a portion of it attached.
John
John Blakley Wed, 03/11/2009 - 05:14
The forum wouldn't let me attach a file if I edit my own post. I had to reply and then attach =)
John
adamclarkuk_2 Wed, 03/11/2009 - 06:05
Have you applied the ip nbar command on the interface facing your internal network as well.
Other than that your config looks good, is your ACL correct as well as the time on your router ?
adamclarkuk_2 Wed, 03/11/2009 - 06:10
Also, edit your regexp to include swf byt adding a |, ie :-
match protocol http url *.js|*.swf
John Blakley Wed, 03/11/2009 - 07:02
If I could get any of these to work alone, then this would definitely be the way to go. Problem is that it doesn't work with either of them.
John
adamclarkuk_2 Wed, 03/11/2009 - 07:03
What about answers to my earlier post
Maybe try removing the ACL to see if that works ?
John Blakley Wed, 03/11/2009 - 07:08
Oh, I'm sorry I didn't see this one.
Actually, no. I don't think nbar is applied to the internal interface. The time is correct. I'll have to apply it and test it later tonight and I'll let you know.
Thanks Adam!
John
adamclarkuk_2 Wed, 03/11/2009 - 07:26
That will be your problem then as the inspection can not take place, all should be good once you add NBAR to the internal interface.
John Blakley Thu, 03/12/2009 - 06:35
Okay,
I enabled inspection on the bvi and interface do0 (I was connected wirelessly). It still didn't work.
I changed the class-map to "match protocol http mime video/flv and application/x-shockwave-flash, and a combination of the two (application/x-shockwave-flash|video/flv). This didn't work either.
I also tried the "match protocol http url *.swf|*.flv" to try to match the embedded video. I did forget to try the .js filetype, but the other didn't work.
I removed the match statement to make sure the class-map and policy-map/class/drop statement was working. I couldn't get on the internet at that point, and my policy-map had hits on it. So, I have "class-map match-any NO_FLASH" as my class map, and it definitely works. I also tried changing to "class-map match-all NO_FLASH." The latter will work perfectly once I can figure out why my config isn't working.
John
adamclarkuk_2 Thu, 03/12/2009 - 06:43
Gonna need to see your config mate, also what URL are you testing with so I can try to replicate?
John Blakley Thu, 03/12/2009 - 06:57
Here's the config for the class-map, policy-map, and all of the interfaces:
match protocol http mime "application/x-shockwave-flash"
policy-map OUTBOUND
class ROKU-OUTBOUND
priority percent 25
class NO_FLASH
drop
class class-default
fair-queue 256
interface FastEthernet0
description Router Trunk
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
duplex full
speed 100
interface FastEthernet3
duplex full
speed 100
interface FastEthernet4
bandwidth 6144
ip address dhcp client-id FastEthernet4
ip access-group EXTERNAL in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect NEMESIS-FW out
ip virtual-reassembly
ip route-cache flow
speed 100
full-duplex
no cdp enable
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
encryption vlan 1 mode ciphers tkip
ssid ISIS
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
infrastructure-client
interface Dot11Radio0.1
description Normal WIFI
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
description DMZ$FW_INSIDE$
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
service-policy input ROKU
interface BVI1
description Internal Interface$ES_LAN$$FW_INSIDE$
ip address 10.20.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
hold-queue 100 out
access-list 151 permit ip 10.20.1.0 0.0.0.255 any
I was trying both youtube.com and addictinggames.com. I need to be able to block any online game or video anywhere, not just these two sites.
Thanks for looking at this Adam!
John
John Blakley Fri, 03/13/2009 - 04:01
I've been playing around with this for a while this morning, and I can't get it to work. Does it have something to do with NAT?
adamclarkuk_2 Fri, 03/13/2009 - 04:05
Ah Highly possible. Is your ACL matching the post or pre NAT address and have you tried it without the ACL ?
John Blakley Fri, 03/13/2009 - 04:17
Okay,
It does start to match the traffic with the acl removed. I can still get to youtube, but addictinggames.com stopped working (which is what I want). I couldn't get it to work with the mime type under match protocol, but I got it to work with the url *.swf|*.flv|*.js.
How would I be able to get this to work using NAT?
John Blakley Fri, 03/13/2009 - 04:37
I can't get it to match the mime type though.
I pulled this from youtube's "embed this link on your site" code:
http://www.youtube.com/v/5zozqhQa29M&hl=en&fs=1">http://www.youtube.com/v/5zozqhQa29M&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
The mime type that I have set on the match protocol is application/x-shockwave-flash, but I'm not seeing hits on it.
John
adamclarkuk_2 Fri, 03/13/2009 - 04:39
At least we have progress.
Lets focus on the ACL first. Are you matching on the pre or post NAT, put both in the ACL and see which gets the hit, it should be the post NAT address
John Blakley Fri, 03/13/2009 - 06:28
Okay,
Yes it matches my external address of 99.x.x.x, and it doesn't match the internal address.
Even though it was matching on it, I could still get to youtube. My match statement was like:
match protocol http url *youtube.com*
I also tried:
*.youtube.com
*youtube.com
Nothing I tried will block the traffic. I know that I'm missing something because I've seen too many documents that verify this is configured correctly.
John
adamclarkuk_2 Fri, 03/13/2009 - 06:43
Hi mate
So you setup is similar to this :-
class-map match-any test
match protocol http url "*youtube.com"
match protocol http url "*youtube.com*"
policy-map test
class test
drop
Can you post the out of :-
sh policy-map interface
