ASA - NAT/PAT
Mar 10th, 2009
ASA Version 7.2(3)
Global NAT on outside Interface plus two Static PAT on the same outside address.
But the static PAT don't work.
Configuration as follow:
(omitted)
name 192.168.100.60 LAN_RDP
name 192.168.100.100 LAN_SMTP
access-list inside_nat0_outbound extended permit ip 192.168.100.0 255.255.255.0 10.1.10.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 10.1.10.0 255.255.255.0
access-list outside_access_in extended permit icmp any any echo-reply log disable
access-list outside_access_in extended permit tcp any host 195.254.241.194 eq 3389 log disable
access-list outside_access_in extended permit tcp any host 195.254.241.194 eq smtp log disable
access-list outside_access_in extended permit ip any any log disable inactive
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 195.254.241.194 3389 LAN_RDP 3389 netmask 255.255.255.255
static (inside,outside) tcp 195.254.241.194 smtp LAN_SMTP smtp netmask 255.255.255.255
access-group outside_access_in in interface outside
Some suggestion?
Ivan Martinon Tue, 03/10/2009 - 08:13
Is this ip address "195.254.241.194" the same as what the outside interface has assigned to it? if it is then go ahead and change your static lines to show like this:
static (inside,outside) tcp interface 3389 LAN_RDP 3389 netmask 255.255.255.255
static (inside,outside) tcp interface smtp LAN_SMTP smtp netmask 255.255.255.255
Give that a shot.
