Traffic redirection on Vlan router
Answered Question
Mar 10th, 2009
I have Cisco 2621 router set up as Vlan router.The default getway is pointing to our backup DSL circut.I need to direct traffic from one of the VLans to our primary circut. I can't change the default getaway though.Just this one VLan needs to go thru primary getaway.What would be the easiest way to do that?
Thank you,
Correct Answer by Jon Marshall about 8 years 2 weeks ago
PBR would be the way to go ie.
vlan you need to redirect = 192.168.5.0/24
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
route-map REDIR permit 10
match ip address 101
set ip next-hop
then on sub-interface for 192.168.5.0/24 network
int fa0/0.5
ip policy route-map REDIR
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 03/10/2009 - 09:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
set ip next-hop
int fa0/0.5
Jon
angelmed Tue, 03/10/2009 - 11:41
Thank you! I've used policy based routing solution suggested by Jon. Works great!
