Following a reboot, publisher CPU utilisation at 100%
Mar 10th, 2009
I have a problem where if I reload the Call Manager publisher, the CPU utilisation stays at 100% constantly in task manager. The problem goes away if I disable the Cisco Secutity Agent, the utilisation gradually falls to a more normal 10% or below. If I disable and unistall the CSA, the publisher comes up ok. I tried loading on the latest version of CSA 5.2.0.272-3.1.2 but the fault remained the same after reboot.
The setup is one publisher and two subscribers in the cluster.
The version of Call Manager is 4.1(3)SR5D.
Has anyone seen this happen before.
Any help or ideas will be greatly appreciated.
Thank you.
