Cisco ACE - CLSRST connection state
Mar 10th, 2009
hi,
During performance testing with IBM Rational Performance Tester tool with 500 users, I noticed above 4000 connections in 'show conn' display and most of the connection states showed as 'CLSRST'.
On doing search the meaning I found is
'CLSRST-ACE closed the connection by resetting it'
What does it mean and is it normal to see so many CLSRST connections.
Thanks.
