ACE module and port redirection issue
Syed Iftekhar Ahmed Wed, 03/11/2009 - 12:08
  • Blue, 1500 points or more
Port Redirection will definitely work.
Question is if both real servers are really listening on the ports you configured & have the resources (web pages)you are trying to access.
This can be verified by hitting each real server using the url that gives you 404 ( including port# you defined under real server in th ehttp request).
For example If you are hitting a page using VIP http://10.128.170.95/page_A and it gives you an error
then try hitting the real servers on the ports configured and see if you get any errors
for e.g access reals (from the segment they are available)
http:///page_A:50081
and see if you get any errors.
Syed Iftekhar Ahmed
Issue solved:
After some sniffer traces and working with TAC, we found that the issue was not with the ACE modules but with the config of the servers:
Jeff in your Virtual Host config for sc add smtest.bbtnet.com:80, you will also either need to remove the *:80 for the default_host of this plugin or make it more specific, like powerimage.bbtnet.com:80 or whatever that sites DNS name is, regen your plugin, copy to web servers and restart the JVM. Once that is done you should be able to retest.
John...
