Is this a CSCsv95235 redux or CSCsw39641/CSCsw88378
Mar 10th, 2009
A Netconfig job scheduled at 20:00, Mar 07 deployed the one-line global config fine, but remained in "Running" state. User-initiated stoppage results in "Stop initiated" state. This looks like CSCsv95235 but that had been patched. I happened to have debug on for Netconfigclient. The job seems to be reappearing in Netconfigclient.log over and over. Is this CSCsw39641/CSCsw88378 instead?
casuser 7396 14413 0 Mar 07 ? 3:56 CSCO.2239 -cw:jre lib/jre -cp /opt/CSCOpx/MDC/tomcat/shared/lib/MICE.jar:/opt/C
Overall Rating: 5 (4 ratings)
Joe Clarke Tue, 03/10/2009 - 12:49
A one-line job should not trigger CSCsw39641 unless the remote window size was sufficiently small. CSCsw88378 is a possibility if the credentials in DCR are wrong. CSCsv95235 is also a possibility depending on the device type. Have you applied any new xdi.jar patches lately?
Netconfigclient debugging is useless here. Netconfig jobs require Config Job debugging, and the whole job directory is required for proper troubleshooting. However, in this case, more thread dumps are also required. Therefore, a TAC Service Request is recommended.
yjdabear Tue, 03/10/2009 - 13:00
Neither of the CSCsw looks the part.
Currently installed xdi.jar is the one patched for CSCsv95235, which was affecting only Netconfig jobs deploying per-interface commands.
ls -al xdi.jar
-rwxr-x--- 1 casuser casusers 5011319 Jan 20 22:40 xdi.jar
digest -a md5 xdi.jar
326986eef9c9e46801a8623014ddd07e
Joe Clarke Tue, 03/10/2009 - 13:10
This is my xdi.jar, and it has fixes for all three bugs. You have probably found a new bug.
Martin Ermel Thu, 03/26/2009 - 10:59
is there a new xdi.jar available? I just received xdi.jar from TAC with a MD5 checksum of f975e723e3dfe8fa18af49a5f619bc9b on windows.
According to the information from TAC the checksum is correct - I just want to make sure that the file is up-to-date - perhaps including a patch for a new bug found by ydabear.... ?!
@ydabear: thanks for mentioning these bugs -it saved me a lot of time!
yjdabear Thu, 03/26/2009 - 11:02
That's the first patch I received for CSCsv95235 (and maybe SCsw39641/CSCsw88378 too). The one with checksum 326986eef9c9e46801a8623014ddd07e is what I have in use right now.
The issue in the first post is still being investigated.
Joe Clarke Thu, 03/26/2009 - 11:03
I haven't produced any newer xdi.jar files for RME 4.2. The MD5 already mentioned in this thread is my latest, which includes my fixes for the three aforementioned bugs.
Martin Ermel Thu, 03/26/2009 - 11:21
this would mean that the file I did get is not the latest !?
the SR is 611068151, Joe could you please provide the latest file to the CaseOwner or tell her how or where she can get the file?
yjdabear Thu, 03/26/2009 - 11:37
Martin,
I find pointing to the corresponding forum thread directly usually gets the TAC engineer in the right direction really quickly. Obligatory disclaimer: YMMV :P
Martin Ermel Thu, 03/26/2009 - 14:06
you are absolutely right ! and that's why I opened the case with only referring to this thread and just a few additional words :-)
it is as you said : YMMV :-)
this forum is really helpful!
yjdabear Thu, 03/26/2009 - 19:53
Just saw the email from the watchdog script that it detected a second ConfigMgmtServer at 22:32:26. I should have the thread dumps shortly.
