Incorrect Default Gateway on a PC but still able to route off net
Answered Question
I have a PC on 10.1.2.x /24 with a correct def gatewat of 10.2.1.254. If I change the def gateway on the PC to be, for instance, 10.1.5.254 but leave the IP address of the PC as 10.1.2.x, the PC is still able to ping off net and route out to the Internet. I know it may be basic for some of you experts, but I am curious on how this can happen. I flushed the PC arp tables too.
THanks
Gene
Correct Answer by pvezina about 8 years 2 months ago
Hello Gene,
The routers have a function that is enabled by default that's called "proxy-arp". The PC with the wrong gateway will still ARP to get the MAC address of this IP address. This ARP will be a broadcast at layer-2, so the right default-gateway will see it.
When the router sees this ARP request it thinks: "Mmmm, I know a route to that IP address; even if it's not in the right subnet I'll answer the ARP request with my MAC address". This is called proxy-arp. So the PC will still get the MAC address of the router and everything will work.
This behaviour can be disabled with this command at the interface:
"no ip proxy-arp"
Then the PC with the wrong def gateway will stop working, if you flush the ARP table of course...
Hope this helps,
Patrick
Overall Rating: 5 (2 ratings)
adamclarkuk_2 Tue, 03/10/2009 - 12:45
  • Silver, 250 points or more
Take a look at netstat -rn to see if any routes are having around on the PC.
Correct Answer
pvezina Tue, 03/10/2009 - 12:47
Hello Gene,
"no ip proxy-arp"
Hope this helps,
Patrick
Familar with proxy-arp. Had issues with it on by default on a PIX. Was not sure if a 3550 or 3750 had the same feature turned on by default. Actually the PC is plugged into a 3560 which uplinks to a 3550 which uplinks to the 6509. I believe the routing is handled at the 3550, which is probably where the proxy arp is turned on. So, this is probably why and there is no other magic going on. I will check the arp tables as the mac address should be the same for both the wrong def GW and the right def GW.
Gene
glen.grant Tue, 03/10/2009 - 16:17
  • Purple, 4500 points or more
Generally it is recommended to have proxy arp turned off.
