ACS 4.2 with RSA
davidcruise
we have the vpn users authenticate using RSA token , & ACS configured with RADIUS token server as the in the selected databases for unknown user policy ,
the problem is when we updraded from ACS 4 to Release 4.2(0) Build 124 a problem happened , sometimes authentication works & sometimes don't , & give this error in the authentication failure code : External DB reports error condition.
Yudong Wu
Level 7
Level 7
it looks like hit this bug CSCsu86529.
Thanks for your reply , in the bug description the action is to set
"fail back retry timeout" to 0
is this option in the acs ?
Yes, it should be in ACS.
There are two options under the RADIUS Token Server Configuration
1. Timeout - in seconds
2. Fallback Retry Delay - in minutes
Change item 2 to 0.
