Re: Cisco 2821 Vsec with Advanced IP Services
m-laing
I am configuring a Cisco 2821 router VSEC with Advance IP Services and I am trying to configure the router using SDM. When I connect to the router using SDM I am not seeing the VPN wizard. Do I need to configure anything additional to see the easy VPN module. Can you outline the steps to set-up esay VPN server on the router? Sh version says I have one VPN module
d.haeni
Level 4
Level 4
From what you've attached you're using SDM Express, which is not the same as SDM (the latter uses a PC Client)
Look at the Q&A for differences and ways to change to proper SDM:
http://www.cisco.com/en/US/prod/collateral/routers/ps5318/prod_qas0900aecd800fd11b.html
Once you're using SDM, yes, you can configure EZ VPN Server (samples from various versions of SDM):
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/application/notes/EZVPNSan.pdf
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/EZVPNS.html
/David
