Cat6500 - Unable to session into any module
Mar 10th, 2009
I am trying to session into any module (for e.g. FWSM) via console and getting the below. This was working before. telnet on the management IP is working though. Please assist.
CAT6500>se sl 1 pr 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 127.0.0.11 ...
% Connections to that host not permitted from this terminal
jorge.calvo Tue, 03/10/2009 - 16:15
  • Bronze, 100 points or more
Have you checked if console lines are configured on the cards you try to connect apart from vty lines?
