Configuring Devices
Mar 10th, 2009
I have more than 200 devices which are not in LMS as SNMP is not configured on them.
I can use Netconfig to configure devices which are in managed state in LMS.
Is there a way I can configure SNMP in all those 200+ devices which are not in managed state by using LMS?
If no is there any alternate solution than just to go and do it manually for all the devices.
Joe Clarke Tue, 03/10/2009 - 15:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will have to configure some basic commands on the devices before they will be manageable. SNMP is one such example. You will have to configure the commands manually, or using some other tool outside of LMS. You could develop a script in Expect or Perl to deploy these commands to these 200 devices.
