a-vazquez Mon, 03/16/2009 - 11:23
  • Silver, 250 points or more
Do you get the following error:
"Could not collect inventory: Login ID or password or security policy is invalid"
Explaination: Login or password is invalid for the deployed device, or the security policy attribute is mis-set. As a result, Cisco MNM cannot fully discover the device.
This should help
http://www.cisco.com/en/US/docs/net_mgmt/mnm/2.8.1/user/guide/trblsht.html#wp1025588
anikas Mon, 03/16/2009 - 12:50
  • Cisco Employee,
You will need to perform standard unix password recovery. This does require two things. Physical access to the box and the solaris install CDs.
I have included a URL from Sun using Solaris running on a X86 platform.
You need to determine if you are runing on X86 or opteron. You can find both procedures on Sun's site.
http://sunsolarisadmin.blogspot.com/2007/03/how-to-resetrecover-root-password-in.html
