ASA 5510 ASDM Setup for the fisr time help
Mar 11th, 2009
Hi Experts,
I have a ASA 5510 device with me and i would like to download ASDM from ASA to my Windows's PC.
can you let me know the Steps please.
Kiran Kumar CH
JORGE RODRIGUEZ Wed, 03/11/2009 - 08:43
  • Green, 3000 points or more
Kiran, how far are you on the initial configuration of the firewall, the asdm installation in your machine is fairly simple provided you have IP connectivity to the firewall from your local LAN.
Follow this link Using the Startup Wizard section for asdm
http://www.cisco.com/en/US/docs/security/asa/asa72/getting_started/asa5500/quick/guide/setup_b.html
If you still need help let us know.
PLS rate helpful posts if it helps
