03-11-2009 04:13 AM - edited 03-18-2019 10:39 PM
Hi all,
how can i make read-only user to access the unity 4.2 - the administration system
just to review.
Thanks In advance
03-11-2009 06:33 AM
In Unity admin, go to Class of Service and create a new CoS. In the new CoS, go to System Access and give it read access to administration. Then create a new subscriber and assign this CoS.
Hope this helps.
Brandon
03-11-2009 07:03 AM
Thanks to you for your help
i tried but i am facing below error :
Server.CreateObject(AvSaLocalization.AvSaLocalization.1) failed.
This is most likely an error with a DLL, probably AvSaLocalizationSvr.dll or perhaps AvSaLocaleInfoSvr.dll.
Check that these files are present, and registered with REGSVR32.
Also be sure that the appropriate MsgStoreRes.dll file is present.
Cannot continue.
(From: Global.asa: hr=0x80070005)
03-11-2009 07:07 AM
Have you tried registering the referenced DLLs using regsvr32?
Brandon
03-11-2009 07:28 AM
This link should get you fixed up:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801651f9.shtml#k1
Hope that helps,
Brad
03-11-2009 07:58 AM
Hi ,
some thing strange happen,,
i can access the unity admin page without any authentication after i made the above procedure (Cisco Dec.)
what have i do to solve this issue,
just i need read only user
03-11-2009 08:24 AM
You'll need to specify a new Class of Service and configure the System Access portion of it for whatever you want your user to have access to.
Brad
