T.38 Fax, MGCP and SIP
Mar 11th, 2009
Hallo,
we have a Callmanager 4.1 with a Fax- and Voicemailserver (Callisto with Capi). The Faxserver is termination on H323 IOS-GW whis the E1 to PSTN.
This works fine.
Now we will upgrade for CUCM61 and will use the Gateway with MGCP. The Callisto Fax-Server now can SIP. Can we use MGCP and SIP simultan on the IOS-GW ? Then the SIP-Trunk on CUCM6.1 works not with T.38.
Any ideas or how do you do that?
MfG
Dieter
Nicholas Matthews Wed, 03/11/2009 - 19:00
  • Red, 2250 points or more
If you're switching your H323 gateway to SIP there shouldn't be problems.
If not, I don't understand what you're asking - can you try rewording?
-nick
decbuw007 Thu, 03/12/2009 - 00:37
Hallo,
the Problem is the Faxserver. The old config works over H323 on the IOS-Gateway (Cisco3845), but with MGCP can we not use H.323 on this Gateway simultan. The following routes were open to us:
1. At the Callmanger H.323 Gateway - this does not work 2. At the Callmanager SIP-Trunk with the Faxserver SIP-Version - this does not. For both the call manager switches not to T.38.
Now the question is: can I use the fax server (SIP) on the IOS MGCP gateway to connect?
So, MGCP and SIP simultaneously on the C3845?
mfg
Dieter
Nicholas Matthews Thu, 03/12/2009 - 18:16
Hi Dieter,
You can simultaneously use MGCP and H323 as long as it's not for the same PRI. The same goes with SIP.
-nick
decbuw007 Tue, 03/17/2009 - 07:26
Hallo,
and thank you for the answer, but i have no found an configuration-example for this Szenario.
HICOM - (E1-Qsig) - C3845 - (MGCP) - CUCM6.1 .... C3845 - (SIP) - Faxserver
Nicholas Matthews Tue, 03/17/2009 - 08:08
I would do a Cisco search on two terms:
"HiCom PRI"
"Sip trunk configuration CUCM"
You should find enough configuration examples there to make sense of this. There won't be one guide that has your entire call flow since it is modular.
-nick
Chad Stachowicz Tue, 03/17/2009 - 15:08
  • Silver, 250 points or more
I agree, basically each endpoint on the router can be controlled by any one protocol. Therefore you should be reading the guide for that potocol and how to use it for the specific endpoint.
decbuw007 Mon, 03/23/2009 - 01:44
Hallo,
I have tried the following, but that is not part of the sip (dial-peer voice 1028 voip) processed. Where is the error ?
mfg
dieter
card type e1 0 0
isdn switch-type primary-net5
voice-card 0
voice service voip
no supplementary-service h225-notify cid-update
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface GigabitEthernet0/0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
control-plane
voice-port 0/0/0:15
no echo-cancel enable
echo-cancel coverage 64
cptone DE
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server pubphone
ccm-manager config
mgcp
mgcp call-agent pubphone 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
mgcp tse payload 102
no mgcp timer receive-rtcp
mgcp profile default
destination-pattern 1028
session protocol sipv2
session target ipv4:<-faxserver->
dtmf-relay sip-notify
codec g711alaw
ip qos dscp cs5 media
no vad
dial-peer voice 100 pots
service mgcpapp
incoming called-number .
direct-inward-dial
port 0/0/0:15
