FWSM authentication error when running inventory
Mar 11th, 2009
I'm again attempting to perform inventory on a FWSM on a Cat 6513. The credentials appear good, the snmp v2 community string appears to be good, the device is configured for snmp and ssh access and has been reverified (string/username-password) on the device and in ciscoworks (CS/RME). I have adjusted the SNMP timeout to 30 seconds...However when running the inventory, it get the following error:
Transport session to device failed. Cause: Authentication failed on device
any thoughts on this?
Joe Clarke Wed, 03/11/2009 - 11:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is the same problem you've seen in the past. Either the SNMP credentials are wrong on the FWSM or in DCR, the SNMP packets are not making it to the FWSM, or the FWSM is not configured to allow the LMS server to poll it. A sniffer trace on the LMS server of SNMP traffic to this device will show you what credentials RME is using, and whether or not replies are making back to the LMS server.
A sniffer trace on the FWSM side will tell you if the SNMP packets are making it to the device.
A visual inspection of he FWSM config will show you if the IP address of the RME server is allowed to poll the FWSM with SNMP.
Bruce Summers Wed, 03/11/2009 - 17:47
I know, I know...same old problem...just getting back to it...havent put a sniffer on it (but will), snmp creds are correct on fwsm and dcr (changed, verified and reverified)...fwsm is set to allow polling from the LMS server "snmp-server host poll community "...
i'll stick the sniffer on it tomorrow and see what i get...
bruce
Bruce Summers Thu, 03/12/2009 - 14:15
Alrighty J,
You were (as usual) correct...after getting the sniffer on there, and a bunch of packet capturing analysis, I found that though TCP port 161 was open, UDP port 161 was not...once I had UDP 161 opened, BAM, worked like a champ...
thanks for pointing me in the correct direction...
