DateTime configuration
Answered Question
Mar 11th, 2009
CUCM 6.1(1)
I have configured system --> Date/Time Group with "Eastern Standard / Daylight Time. I have partitions configured with the same time zone. But this failed to work during recent time change for Daylight time.(3 days ago). Is this a bug or I am missing something?
The CM itself is synced with an NTP and has successfully adjusted for correct time, but my partitions which have TOD routing failed to work.
rdianat
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Rdianat,
Bug Alert!!
The phones display wrong time because of this bug CSCsy25150 : 7960 and other phones incorrect time after DST on March 08,2009
Symptom:
Certain models of Cisco IP Phones fail to get the time information from the Cisco Unified Communications Manager server component.
Cisco IP Phone Models: 7905, 7910, 7912, 7920, 7921, 7925, 7935, 7936,7937, 7940, 7960
Time of Day routing will also be an hour behind.
Conditions:
Any first generation IP Phone registered to Cisco Unified Communication Manager 5.1.X and above where Daylight Savings Time changes are in affect.
-and/or-
Cisco Unified Communication Manager 5.1.X and above where Time of Day routing is being used
Workaround:
1. Using CUCM Admin go to: System---Date / Time Group
2. Create new Date / Time group with one hour extra of local time.
3. Go to System --- Device pool
4. Create a New Device pool and assign the (one hour extra Date time
group) to this device pool.
5. Assign the new Device pool to and Cisco IP Phones that are displaying
the incorrect time.
NOTE: This workaround action will need to be reversed on 03/15/2009 as the
CUCM time update will occur. Please plan to change your Device pools back
to
the original Date / Time group accordingly.
**Here is the Patch inf**
CSCsy25150 workaround cop file is posted
Voice and Unified Communications > Cisco Unified Communications Manager Version X.Y > Unified Communications Manager/CallManager Utilities
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=UCM+COP+Files&mdfid=281941895&sftType=Unified+Communications+Manager%2FCallManager+Utilities&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+Unified+Communications+Manager+Version+7.0&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&modifmdfid=&imname=&hybrid=Y&imst=N&lr=Y
ciscocm.dst_march_2009.html
****IMPORTANT*****
This patch is a temporary workaround for the March 2009 DST issue.
You must upgrade before November 1, 2009 to a Unified Communications Manager version containing the fix for CSCsy25150 (CUCM is not sending Daylight Saving Time updates):
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy25150
Installation Instructions for Unified Communications Manager Daylight Savings Time (DST) patch file:
File Name: ciscocm.dst_march_2009.cop.sgn
MD5 Sum: d4:f5:e2:56:29:82:f9:fd:af:44:46:be:2a:e0:8d:f1
Ensure that Database Replication is working correctly before installing this file, you can check this from RTMT or Cisco Unified Reporting.
Install this file only on the Publisher from the "Install/Upgrade" option under "Cisco Unified Communications Operating System Administration."
Wait for 60 seconds.
Ensure that Database Replication is working correctly after the installation is complete.
Restart Cisco CallManager service on all the nodes in the cluster that are running this service.
***NOTE: If you apply a device pack or other update after applying this patch and before March 15, this patch will need to be re-installed.
When a permanent fix is available for November time change a Field Notice will appear here:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_field_notices_list.html
From these ReadMe notes;
http://www.cisco.com/web/software/282204704/18582/ciscocm.dst_march_2009.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Wed, 03/11/2009 - 06:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rdianat,
Bug Alert!!
Symptom:
Conditions:
-and/or-
Workaround:
the incorrect time.
to
****IMPORTANT*****
Hope this helps!
Rob
