Hythim Ali El Hadad Wed, 03/11/2009 - 16:38
  • Silver, 250 points or more
yes you can but consider its bad effect
if hub,it will load your network with high traffic which may affect your voice quality as the number of IP phones increase
if switch,it is better to be POE or you'll need to have a power cube for each IP phone
