TAPS error. Pls Help !!!
Mar 11th, 2009
I am deploying TAPS for our CCM cluster.
CCM version is 5.1.3
I installed and configured TAPS on the IPCC Express server.
I used the BAT tool to input user phone configurations with dummy MAC addresses.
I Auto-Register a new phone by placing it on the network.
I am able to call TAPS pilot number.
I follow the instructions and input the desired directory number. Then TAPS gives me a message stating that the auto-registered phone already has a valid configuration. And the call got dropped.
I checked the TAPS log on the CCM. I see the following message "Telephone Number belongs to a partition different from the Auto-Registration partition set for the primary Cisco CallManager."
I checked that both the auto-register phone DN and the desired DN are in the same partition.
Can you please help me fix the issue?
sebastien_michelet Wed, 03/11/2009 - 14:06
did you have the auto-registration enabled under System->Unified CM at the time you called TAPS?
balasundaram.k_2 Thu, 03/12/2009 - 02:06
Hi Sebastein,
I have auto-registration enabled on the all the CCMs in the cluster when I dial TAPS from the auto-registered phone.
mcibanez Mon, 04/06/2009 - 05:53
Hi Bala,
I'm experiencing the same issue.
Did you ever find out what was the problem?
Thanks in advance,
htluo Mon, 04/06/2009 - 06:23
Try to go to "System > Service Parameters > Cisco TAPS Service". Set "
Auto-Registration Options for TAPS" to "Allow Auto-Registered Phone to reset with any profile".
Then restart TAPS service.
mcibanez Mon, 04/06/2009 - 10:09
Thanks Michael, but I already tried that and it didn't work. I'm still getting the same error.
And anyway, the extension I'm trying to register with is one associated with a BAT..... device name.
mcibanez Sun, 04/19/2009 - 23:54
Hi all,
Just in case anyone faces the same problem ever...
In my case, I solved it by enabling autoreg in the Pub.
My cluster is a big one so Pub's CM service is not running, and at the beginning I just enabled autoreg in one Subs (which is needed for phones to register)
But as soon as I enabled autoreg also in Pub, phones are getting their right configuration.
I don't know exactly why, cause there is not much documentation about TAPS, but that solved my issue.
Sharif Alkatib Mon, 06/08/2015 - 12:36
My solution was to ensure that auto registration was enabled under Cisco Unified CM and ALSO enabled on the same Cisco Unified CM Group.
The key was that the servers that I had enabled auto-registration on weren't matching the corresponding Unified CM Group! Once I corrected that the phones began to work on TAPS no problem.
