didyap Tue, 03/17/2009 - 13:49
  • Silver, 250 points or more
To set the ARP proxy ARP mode, use the config network arpunicast command.
config network arpunicast {enable | disable}
migilles Sat, 03/28/2009 - 20:42
  • Cisco Employee,
To enable proxy ARP, arpunicast should be disabled.
config network arpunicast disable
This command is removed from the latest WLAN controller versions.
When proxy ARP is enabled, this allows the WLAN ontroller to answer any ARP requests on behalf of the client. If not known, it will forward the ARP request over the air at DTIM.
stevenewson Fri, 03/27/2009 - 06:17
Many of our customers have experienced one-way audio issues with ARP unicast enabled. Hence the reference to disabling Proxy ARP mechanisms.
