WRV210 SIP ALG disable?
Mar 11th, 2009
Can i disable the wrv210 sip alg ? it messes with my voip provider and must be disabled...i use a pap2T adapter and it works fine for outgoing calls...but after a while incoming calls half ring and i cant answer them.
ntarazi Thu, 03/12/2009 - 12:35
  • Cisco Employee,
SIP ALG is not supported on the WRV210
