ICMP weirdness
John Blakley
All,
I've got a remote site. The remote site has a 2800 series router and it's connected to a L2 switch.
Configuration:
Serial WIC: 172.5.5.1
FE0/0: 10.126.5.1
10.125.5.1 second
10.15.5.1 second
The default-gateway on the switch is set to 10.126.5.1.
Problem/Weirdness:
I can ping across the wan to a host connected to the switch on the 10.126.5.0 subnet and the 10.125.5.0 subnet.
While running wireshark, I get two replies from each ping to the 10.125.5.0 subnet ONLY.
Pinging 10.126.5.0 host will result in:
request
reply
request
reply
Pinging a host on the 10.125.5.0 subnet results in:
request
reply
reply
request
reply
reply
Has anyone seen this? I'm "assuming" that it's because the router is receiving the packet on the secondary address and could be sending a reply from both addresses, but that's still really odd. My pings don't timeout, traces don't timeout, but I still get the double replies. My traces look right too. There are no "extra" hops per se.
Any ideas?
John
HTH, John *** Please rate all useful posts ***
10 Replies 10
Richard Burts
John
I have not tested this but believe that you are correct that it is related to it being sent to the secondary. Since you are pinging (or tracing) to the router itself and not to something through the router, then the router must receive it and must generate a reply. By default when Cisco routers generate packets the source address is the primary address of the outgoing interface. I believe that this accounts for one of the responses. I believe that the router then generates a second response so that it can respond from the address to which the original packet was addressed.
Rick
Rick
I tried the same thing with another site that has a similar setup, and I'm not seeing the problem there. :(
John
John
Is the other site running the same version (and perhaps same feature set) of code?
Rick
Rick
This just gets better =)
In answer to your question about feature set, yes, both are running C2800NM-ENTSERVICESK9-M, Version 12.4(1a).
Now the cool part about this is that you remember it has 10.126.x.x, 10.125.x.x (as secondary), and 10.15.x.x? Well, I installed Wireshark on a server that's on the 10.126.x.x (I don't think they have any servers on the 10.125.x.x), and I pinged a device from the 10.126.x.x server to a host on the 10.125.x.x.
The result was:
request
reply
reply
reply
reply
request
reply
reply
reply
reply
I have no clue where to look. It sounds like a loop somewhere.
John
John
Perhaps running debug on the router ie. debug ip packet with an acl. Obviously this could seriously degrade router performance.
Jon
Jon,
I wouldn't be able to do this until after hours, and like you said it could degrade router performance. If it did that to the point of not being responsive, I could be in trouble seeing as I'm remote. I guess I could do a "reload in" scheduled for an hour or longer later in case I locked myself out. I wonder what that would do to the config of the router to be rebooted in the middle of high processing times, or if it would even be able to reload during the high processing times.
Any other ideas I could do during the day?
John
John
Understood and very sensible to be honest.
What happens if you ping a device using the other secondary address ie. 10.15.5.x
In your wireshark capture are the source and destination IP addresses the same. In fact is there any difference in the 4 replies at all ?
Jon
Jon,
If I ping one host from the server on the 10.126.5.x subnet, everything is fine.
If I ping one host on the 10.125.5.x subnet from the server on the 10.126.5.x subnet, I get the 4 replies per request.
If I ping a host from the 10.15.5.x from the server at 10.126.5.x, everything is fine.
The difference:
10.15.5.x is on it's own vlan.
10.126.5.x and 10.125.5.x share vlan 1.
Thanks Jon!
John
John
Can you post output from wireshark for a ping that works correctly and one that doesn't.
Also are all the subnet masks correct on both the router and servers/hosts.
Could you also post "sh run" from router.
Jon
Here's the "important" stuff from the router:
interface Loopback0
ip address 172.21.55.1 255.255.255.0
interface FastEthernet0/0
description Internal Network
ip address 10.125.5.1 255.255.255.0 secondary
ip address 192.168.5.1 255.255.255.0 secondary
ip address 10.126.5.1 255.255.255.0
ip access-group 123 in
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description AT&T Frame Relay - Local DLCI 255
bandwidth 1544
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
interface Serial0/0/0.1 point-to-point
description St. Louis - IPFR ePVC
bandwidth 1544
ip address xxxxx
no ip mroute-cache
frame-relay interface-dlci 1000 IETF
router bgp 65155
no synchronization
bgp log-neighbor-changes
network 10.15.1.0 mask 255.255.255.0
network 10.125.5.0 mask 255.255.255.0
network 10.126.5.0 mask 255.255.255.0
network 172.20.155.0 mask 255.255.255.0
network 172.21.55.0 mask 255.255.255.0
network 192.168.55.0
neighbor 172.20.155.2 remote-as 13979
no auto-summary
no ip classless
ip route 10.15.1.0 255.255.255.0 10.126.5.5
After my initial post, I realized that the switch they have there is a Dell L3 switch. The switch has two vlans: one for the phones at 10.10.55.0 and one for the 10.126.5.0 and 10.125.5.0 subnets. The default gateway is 10.126.5.1 on the switch.
Here's one that works; I'm going to try to paste this:
No. Time Source Destination Protocol Info
3805 15:49:52.900597 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
3808 15:49:52.938788 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
3869 15:49:53.902375 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
3870 15:49:53.930511 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4106 15:49:54.905232 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4116 15:49:54.967510 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4188 15:49:55.906279 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4192 15:49:55.948929 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4251 15:49:56.907252 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4255 15:49:56.944606 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4318 15:49:57.909204 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4322 15:49:57.988093 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4379 15:49:58.911120 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4395 15:49:58.956752 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
4460 15:49:59.912150 john-blakley.glazers.info 10.126.5.172 ICMP Echo (ping) request
4463 15:49:59.949100 10.126.5.172 john-blakley.glazers.info ICMP Echo (ping) reply
