CDMA remote antenna
Mar 11th, 2009
Hi. I have a 2800 with a 3G-CDMA hwic in it but service isnt terrific. If I move it outside then its great. So what I need to do is find an external weatherproof antenna but am having no luck. This document shows acceptable cables and antennas but the antennas it shows are indoor use only.
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/3hwicdma.html#wp1146724
Any ideas appreciated, thank you!
Bob
dennischolmes Tue, 03/17/2009 - 13:55
  • Gold, 750 points or more
Contact TESSCO and ask for the CDMA external antenna that are vehicle mounted for the 3200MAR. You can use these antennae outdoor.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
