NAC Custom Check to run command
Mar 11th, 2009
hi,
i have a case where i want to check whether the computer has join the microsoft domain or not.
after searching, i found the effective way is to run command nltest.exe. nltest.exe is a command to check trust relationship between workstation and domain controller.
is there any way that custom check can do this ? in CAM document, only registry, file, service, and application check.
this is the link from Microsoft : http://support.microsoft.com/kb/158148
example:
C:\>nltest /server:test3 /sc_query:testd
Flags: 0
Connection Status = 0 0x0 NERR_Success
Trusted DC Name \\TEST2
Trusted DC Connection Status Status = 0 0x0 NERR_Success
The command completed successfully
Can Clean access agent do the command line check and interpret the result ?
thanks,
yd
Daniel Laden Fri, 03/13/2009 - 22:41
  • Cisco Employee,
The Cisco NAC Agent will not able to run and interpret the command output.
If the goal is to check whether the computer is a member of a known domain, you can check 'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Domain' to contain the name of the domain.
-Dan
yudi.arijanto Sat, 03/14/2009 - 09:55
Thanks Dan,
Yes, I already plan to use registry check. But in case the user has admin access, he can change the registry easily.
regards,
yd
