LMS 2.6 Software distribution
Mar 11th, 2009
2 records are displayed for every device in step 2 for the RME software distribution process.. .I have included a screen capture of the display issue. The final image distribution work order will only have one device listed and the software distribution completes successfully with out any issue. Step 2, displaying 2 records is not normal behavior.. How can I correct this display issue?
Server info:
Windows 2003 server r2 sp1
LMS 2.6
-CiscoWorks Common Services 3.0.6
-Resource manager Essentials 4.0.6
-Campus Manager 4.0.6
-CiscoView 6.1.5
-Device Fault Manager 2.0.7
-Internetwork Performance Monitor 2.6.0
-No ACS integration
Joe Clarke Wed, 03/11/2009 - 16:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I have found a bug with recent versions of SharedSwimIOS. I filed CSCsy33252 to track this. I can provide a patch for this if you open a TAC service request. However, the workaround is trivial. Simply uncheck the box next to SYSTEM_SW in row 2.
