How to enable Remote Access VPN logs
Mar 11th, 2009
I need to enable logging on an IOS 871 router so we can be able to tell when and what time the users made a Cisco VPN Remote Access connections?
Can anyone please help on pointing me on what are the commands to allow this?
thank you
JamesLuther Wed, 03/11/2009 - 11:12
The logging buffer on the router will only keep a fairly small amount of history therefore you'll need to setup syslog.
Redirect the logs to the syslog server with the following
logging 10.1.1.1
logging trap debug
James
insccisco Wed, 03/11/2009 - 12:13
yes, that is already been setup.
does this mean that nothing has to be done at the router in order for it to start logging remote vpn users login times?
