03-11-2009 10:49 AM - edited 03-15-2019 04:46 PM
I just have a quick question. On a voice port config, when specifying the connection PLAR, do I need to configure the number that is called to ring the port (as in the DID to that line) or do I specify the digits I want forwarded to the CUCM/CME?
I hope that question makes sense. Another way to ask, if someone's DID is 1-800-111-1111 but their internal extension is 2222, would the plar on that voice port be 1111, or 2222?
Or, does it just specify the dial peer to match?
Solved! Go to Solution.
03-11-2009 10:51 AM
You would specify the DN (internal extension).
Hope this helps.
Brandon
03-11-2009 12:04 PM
The following document references CCM 3.x/4.x. However, if you're using a later version, the concepts still apply.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Hope this helps.
Brandon
03-11-2009 10:51 AM
Hope this helps.
Brandon
03-11-2009 11:32 AM
It does and it works.
Thanks!
Now I have to figure out outbound calls...
03-11-2009 11:54 AM
Here's an example of a dial peer for outbound calls:
dial-peer voice 1 pots
destination-pattern 9[2-9]......
forward-digits 7
port 0/0/0
This dial peer will match 7 digit calls with a prefix of 9 and send 7 digits out port 0/0/0. This will essentially strip the 9 before sending the call.
Hope this helps.
Brandon
03-11-2009 12:01 PM
I've got the outbound dial peer configured for pattern 9T
I'm now figuring out what to do to get the CUCM server to send outbound calls to the H.323 Gateway. I can't find where to do that...
03-11-2009 12:04 PM
Hope this helps.
Brandon
03-11-2009 12:16 PM
I think that did it. I didn't know that I needed to put the IP address in the "name" location.
Thanks again!
