Unity 7.0 VoiceMail only installation
tka
Hi ,
Do you confirm that it is not necessary to have an Exchange or Domino Server if we would like to implement Voicemail only with Unity 7.0 . As ingle MCS Server with Unity is sufficient (of course while shoosing the appropriate options).
best regards,
Jaime Valencia
no! of course you need either one!, it's mandatory to have a message store.
Exchange Requirements-Message Store
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html#wp472166
java
if this helps, please rate
java
Rob Huffman
Hi Ramzi,
Unity does require Exchange but if you are using VMO (Voicemail Only) and not UM (Unified Messaging) you can install Exchange "on-box" with Unity. Here is a good thread with some links and great advice from Tommer,Ginger, Randy and Tray from Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbfed10
Hope this helps!
Rob
First, thank you for your response.
For the license, it should be a licence of Unity for Exchange or both types (for Exchange and for Domino) are valid for VMO messaging ?
many thanks!
