Running CER 7.0 on VMware?
Mar 11th, 2009
Has anyone successfully loaded CER 7.0 on Vmware? I know this is not a supported config, but I have run into the issue where CER 7.0 will not run on any of the new, non EOS, MCS Servers such as the MCS 7825-I4-IPC1. I need a temporary solution until 7.03 comes out towards summer that actually supports current server hardware.
Overall Rating: 5 (1 ratings)
Jeremy Ledbetter Wed, 03/11/2009 - 13:47
I have it running under VMWare in a lab for testing purposes only. Seems to work ok, no issues yet.
NPT_2 Wed, 03/11/2009 - 14:15
Good to hear, I may be stuck doing that until they release 7.0(3). Did you have to use any special settings in your vitual machine, or did the standard setting pretty much work?
Jeremy Ledbetter Wed, 03/11/2009 - 14:40
I actually use a MacPro 8-core with 14 Gigs of memory for my VMWare setup. I have all the 7.x products running on it at the same time without any issues - actually quite fast.
Each VM config is similar with 2GB of RAM, 75GB hard drive (can be dynamic) and single CPU. I also remove all the USB, sound and other devices from the profile.
