multi-link T1
Mar 11th, 2009
Hi ,
I am trying to multi-link 3X T1, T1 are errors free , both going from point A to Z..one T1 is 127 ms latency , number 2 T1 is 60 ms, number 3 T1 is 114 ms .
T1 # 1 going trough 2 hopes
T1 # 2 going trough 4 hopes
T1 # 3 going trough 3 hopes
is it ok to link those 3 ?
is there going to be problem ?
is there any multi-link rule about different latencies
Any info or suggestion will be helpfull
Thanks again
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 03/11/2009 - 11:18
  • Hall of Fame,
    Founding Member
"should" be ok. If you search "multilink maxium latency" you will be brought to the documents that details configuration and issues.
Alternatively drop multilink and use regular load sharing for ease of configuration.
