Phone "missing" DST. (7970)
Mar 11th, 2009
I have one phone, a 7970 that does not seem to want to keep up with daylight savings time. The firmware load and device pool seem to be identical to other phones that are registering the proper date and time. Can anyone think of a reason that this phone would still be off time-wise? I can't think of anything that would be causing the time to still be off when all of my other 7970's with the same firmware are on the correct time.
ivillegas Tue, 03/17/2009 - 12:16
One possible workaround for this issue is to reset the IP phone from the Cisco CallManager Administration (CCMAdmin). This allows the phone to obtain the correct time. A power cycle of the phone does not fix the time.
